sleddineinar
Most say 40:1 but I've been running 50:1 in my Phazer II until this year when I fixed the oil injector.
32:1 would mean less gas to oil. If your sled is running good without smoking to bad, and you are not fouling plugs excesively, you should be ok.What 2stroke oil are you using? If you are using a good semi synthetic, you could probably get away with a higher ratio....i.e. 40:1smitymike11 said:I have been running my srv at 32:1. Isnt 50:1 richer? If so am I running mine to lean?
Sno-Xr said:32:1 would mean less gas to oil. If your sled is running good without smoking to bad, and you are not fouling plugs excesively, you should be ok.What 2stroke oil are you using? If you are using a good semi synthetic, you could probably get away with a higher ratio....i.e. 40:1
