clutch fitting
ostacruiser
central Saskatchewan
Would this primary fit my 1994 v-max 500 le
This is a primary clutch from a newer Yamaha snowmobile. It comes complete with everything. 15.6 mm rollers(8mm I.D.), Green/pink/green spring and 8ch weights. I bought it used as a spare for my 1997 600sx, but it will work on any of the newer Yamaha sleds using the YVXC clutch. I am selling it because I sold my V-max. I only used it once, to test to make sure it worked properly, which it did. This is perfect for a spare or replacement to your old worn out clucth. Because item is used I am selling it as is.
The older primary clutches will work on the newer Sleds but not vice versa. You gotta machine some material off the back the fixed shive to make it fit
