ostacruiser
Would this primary fit my 1994 v-max 500 le
This is a primary clutch from a newer Yamaha snowmobile. It comes complete with everything. 15.6 mm rollers(8mm I.D.), Green/pink/green spring and 8ch weights. I bought it used as a spare for my 1997 600sx, but it will work on any of the newer Yamaha sleds using the YVXC clutch. I am selling it because I sold my V-max. I only used it once, to test to make sure it worked properly, which it did. This is perfect for a spare or replacement to your old worn out clucth. Because item is used I am selling it as is.
