WedigSRX
Ok guys, I am tired of trying mis-matched componets and being frustrated with the out come. I have a Hauck # 3 kit, Hauck grass drag kit, and 89A-10 weights.
SRX700
144 studs
.91 track
22-38 gears
89A-10 weights empty
BWB primary spring with (2) shims
Hauck (w) helix (56/50) measures 54-48
Hauck Orange secondary spring 6-1
gutted air box
engine and exhaust stock
rebuilt primary a couple years ago
10,000 plus miles
Not much testing done but it looks like the RPM is way low, like 7800 out of the hole. 8,250 is my target RPM in a perfect world. I pull the weight out of the inner hole and it seemd to come up to 7900. I am thinking I just dont have the proper helix to work with this set-up. Acording to Hauck I should run the 8DN weights but everything I read I should have the 89A-10 weights with the 48/42 helix.
Extra parts
Hauck L 45/39 measures 43-37
Hauck Orange primary spring (is binding took it out)
Silver secondary spring
Stock weights and springs
19-40 gears (grass drag)
From the tuning page I should just order a 48-42 helix, put the stock secondary spring in and add weight, or what do you recommend.
Aggresive trial riding, and drag race friends shorter distances, southern WI mainly. I have not been up north or ran long distances for a number of years.
Any recomendations would be appreciated.
SRX700
144 studs
.91 track
22-38 gears
gutted air box
10,000 plus miles
Extra parts
