95rxl650
when you work on your sled to much?
Pulled the pipes, can, cc cover, checked for wear, retorqued the jack nut and drive axle bolt, adjusted chain tension, recovered, refilled, put exhaust back, loosened track off, checked drive shaft bearings, cracked a beer and patted myself on the back in 29 minutes.
Havent tightened the track up yet as I may replace it tomorrow.
