i have a question for the experts aroud here.
Today i did put plastic skis on my vmax 95 out of a RX-1.
All the job went good but one thing is missing in the page about
the modification here:
http://www.totallyamaha.com/snowmobiles/aaTECH/ausertech/Dave_vmaxSkisrx1.htm
I didn't put back any ski bumper under the spindles,is it bad for the suspension,bolt or saddles?
Cause on photos that explain how to do it,it seems there is no rubber between ski and spindles..
could someone light me up on this.. and if i have to put rubbers again,i just cut my old one to fit there?
i've made a run of 4 hours with it and it's day N night versus my old skis,it handles like a gokart,really love it.
sleddineinar
I put rx-1 skis on a 96 xt this fall, They are way better than the old steel skis. I also did not put the rubber bumpers, I was going to shave them down to fit, but never did. I can't see that it needs them.
super1c
Super Moderator
sleddineinar said:I put rx-1 skis on a 96 xt this fall, They are way better than the old steel skis. I also did not put the rubber bumpers, I was going to shave them down to fit, but never did. I can't see that it needs them.
X2. 96xt rode fine without.
thank you guys,feel better knowing this
YamaChris
I did this mod and just put a flat rubber pad under it, about 1/4". Seemed to work fine.
since i have you guys here, i'll post u another question..
did someone put studs on their tracks and if so, what is the maximum track that can be put there, 1" or 1.25" ?
I have an m-10 suspension i don't know if that change something about the track i can use on
super1c
Super Moderator
I wouldn't go bigger then 1" if your going to stud. Depending on track you will have to trim the lugs at the windows so they don't rub heat exchanger protectors. No biggie did this to all my tracks that I had studded.
