So what i have on the sucker is a bender can, which sounds pretty friggin sweet and stuff. Chainsaw meets crotchrocket.. but it seems to be farting, so we call it. When i go to start it i need to choke it...which is stuck unless i use a pliers to manually close it, that solved the sound problem the first time. i am also running BR8ES plugs in it instead if 9's cause those got nice and black on me when i used them. I just found 2 nice brown plugs in the sled and a brown/ black one. Could the sound be because i am running rich? I had a arctic cat dealer clean the carbs and they said they where pretty bad 140 dollars later.
