Guys - aligning my front end. My trailing arm camber angles are perfect when measured per the shop manual with the angle gauge behind the weld.
Put a level across the ski per Be The Vipers article and I could use some adjustment. Went to loosen the locknut on the lower radius rod - WTH? Who can get a wrench in there? Are you guys taking off the pipes, removing the thru bolt to drop the lower radius rod for adjustment and reinstalling or am I missing something here? No way I can get a wrench on the inside locknut from the underside of the sled!
Also - is it worth it to adjust the ski to level instead of leaving it as the trailing arms are fine? Guessing adjusting to get the ski level is going to throw me out of spec on the arms, but I guess the goal is the ski should be level, right? When I put the angle gauge on the level on the ski, to bring it back I think I need about 3 degrees or so.
Thoughts and advice? Thanks guys.
