ski question
madzx2
Osceola Wi
where can i find the bushing that goes into the saddles? these are srx skis. i dont see them listed in the parts fiche. thanks
i have that part, im looking for the bushings that go into the saddle where the ski bolt goes through.
Nope, they fit into the saddle where the ski mount bolt goes through. Ill take some pics later tonight. Should add that this is for a 00srx 700.
never seen those as a seperate part, they come with the saddle. if your needing some, i seem to have several extras of those saddles i could pop a set of bushings out. let me know. i think they come out?
Im looking for the piece im holding.
I dont have any of those for a SRX. I have some for the vipers and saddles ski's. Not sure if they are the same. I would hit up snowdad on his offer.
Thanks, i am looking for two. I lost them taking my skis off. I had to pound the bolt out and they fell out
how the heck did you lose those? i took a stab at knocking one out and it wouldnt budge. didnt try very hard as to avoid any damage, may need some heat or freeze?
stock yamaha saddled skis from what year srx? your picture almost looks like a 2 piece affair with a collar still embedded in the saddle and the washer seperate? or am i seeing things wrong?
let me know if you want me to pound out a set.
If you use a press, you can press them in or out. I lost a couple from a set of saddles that I had laying around, they just fell out somewhere, I had to borrow them from another set, when I went to use the saddles. They were a little loose so I used some JB Weld.
The bushing that the ski bolt goes through, in the spindle was froze so i pounded it out and they fell out. I misplaced them. The skis are off a 2000 srx. How much would you need for two of them?
i have them at the press, no way that i see to press through one side to get to the other as they push from the outside in. cant seem to get the angle, open for ideas.
yours for shipping costs. however, you may be getting an entire saddle.
c-clamp and a big socket will press them in or out, just reverse the set up and use a smaller socket to remove them.
i used a socket and an extension but i was missing one on each ski so it was a little easier to get one out for the pic.
