Wizzard717
I've done a lot of research on this topic and found a lot of good information but i still have a few questions. First off, i'm planning on gutting the stock no-action skid out of a viper and putting a skidoo sc3 or 4 skid in with 144 tip ups with the hartman tunnel extension. That should raise the rear end significantly along with the boss seat should help the rear. Now the front end is my question. There was a guy on here that had fox float 2's put on his viper...actually carver performance did the work. I'm wondering if just the fox floats alone with raise the front end an inch or 2 ? If thats the case, what exact fox air shocks should be used ? What is the center to center ? Also, is there anything else that can be done to the front end to raise it up so the nose isnt plowing snow in powder ? Anything off the mountain viper that can be purchased and swapped on the flatland viper to help the front end out ?
