I have a TORS problem on my Vmax 600XT -96. After measuring I have concluded that it is the switch on the handlebar that is the problem. Can It be disassembled without messing up the adjustment for the oil pump?
sleddineinar
Yes. You can remove the throttle block form the bars, just undo the cables from the throttle, by first removing the wire clip, then you can pop the cables ends out of the lever.
Thank you and I don't have top make adjustments to the oil pump wire when I reassemble?
If all you do is slip the cable out of the flipper then no.
