lets agree to disagree.
fact being, for the sleds with 300 watt ignitions built 2001 and after, including the sx, vx, vt, and mtn max and excluding vipers and 4 strokes, the following codes apply:
three flash pattern showing .75 second flash with .25 second between = thumb warmer switch circuit.
four flash pattern with the same intervals as above = thumb warmer itself.
one single .75 second flash followed by three .25 second flashes with .25 second between the flashes is the coolant temp sensor and or circuit. on this code, it appears more as a 3 flash code to me because the quick three flashes catch my eye more so than the first flash.
this info is readily available in any of the yamaha service manuals along with the technical manuals as well as listed in the ty tech section.
