Backwoods M Max
My sled started to intermittently flash a .75 second code 3 times with a break. It is now on full time, quite annoying and I'm trying to do research to repair. Discontinuity of the variable resistor (thumb warmer), what is that really? Is the resistor burned out, the thumb warmer open? Looking at the line diagram the signal for the warmer goes through the ecu between the resistor and warmer, but would it tell me that if the wire to the thumb warmer broke or the warmer was open also? The sled has 5700 miles on it, and I hardly use the warmers but I bet the previous owner used them a lot. The bars were rolled down on your lap for trail riding when I bought the sled. It's an 02 mountain max
