This seems to be a pretty decent "do it all" set up:
Primary:
Heelclicker 40-10 set with red spring
Heel: 5,2 grams
Middle: Empty
Tip: Load as much as you can, with a little grinding and making sure the bolts and nuts (used nut on the other end) did not interfere with the clutch pocket, I managed to put 8,3 grams in each, you can put less. (Putting less, you might have to change helix to a 50/40 or different wrap on the spring)
Secondary:
Dalton 50/38 helix
Red Hauck spring @70 degrees.
Thanks to Mrviper700 for the helix tip and the tip about leaving the middle empty.
If your sled does not feel wild with this set up, something might be wrong with it...
Primary:
Heel: 5,2 grams
Middle: Empty
Secondary:
Dalton 50/38 helix
