So I removed one front exchanger protector last Fall because it was banging around loose.The 2 holes where I would rivet the bottom mount plate to are to large for a standard 3/16 rivet to go in.So what is the best way to solve this?Can I perhaps fiberglass the area and then re drill a 3/16 hole to except rivets.I could perhaps epoxy the holes as well and re-drill..but will the epoxy last.Just need to fill in the 2 holes to accept rivets.The top rivet I am not sure if it will accept a rivet either.But want to put studs back on my track for next season.Also I could apply epoxy to the inside of the mount plate to also bond to the protector location to the underside of the exchanger are.
