I have a 2000 Mountain max. I bought a 2001 mountain max as well. on my 2000 the shocks are clevis, and it has a mounting bracket. the 2001 has a forked mounting point. My buddy has a 2001 it has these adapter mounts as well. These machines had them when we bought them. We thought they are stock. are they OEM somewhere? Where can I get another set of brackets?
not on my 01 nor my 00, never seen those before as an oem on all the mtn sleds i have had my hands on.
post those up in the general or maybe the srx/viper for more exposure.
do both the 01's have the fox conversions vs the coil overs consistent with the mtn maxes?
Backwoods M Max
http://www.boats.net/parts/search/Yamaha/Snowmobile/2002/MOUNTAIN MAX 700 - MM700G/SKI/parts.html
Shows a forked style shock on the 02 that monts directly to the upright, no brackets or adapters
That is what is shown
Yes Oem shows a forked connection. My machine had this adapter to an eye to eye setup, and I need another pair of adapters to make my shocks work on my other machine. Anyone know where to buy?
staggs65
are they just the sx brackets by chance?
thefindian
I heard you get them brackets off a 97 sx.
part # 8CV-2376J-00-00? my 97 600 twin with ohlins has a similar looking bracket.
Thanks again snowdad. The fische looks good. I think that is the bracket.
gild
fox
The only way to mount Fox Shocks or older srx Ohlin shocks , aftermarket brackets
gild
Brackets
I was incorrect on the brackets as the bracket could be off a 97SX or a srx
My memory fails me!
My memory fails me!
Snowdad had it right
That is a OEM adapter bracket. Th funny thing is it bolts to the old shock mount, and a bolt straight into the bulkhead. The funny part is that threaded bolt Hole in the bulkhead is already there pre drilled and perfectly aligned. So it works perfectly. And creates a eye to eye shock mount for works/fox/viper shocks.
