mopar1rules
BETHEVIPER said:the upper rod really doesn't turn much. the lower is full rev, all the time.
Very true, but if its detonation like Don believes it is, then the detonation shocks should destroy the upper bearing too I would think. I think its partially a lack of oil issue combined with ethanol in the fuel, which causes the bearing to run dry and then get hot and then its game over. Prolly a combination of a number of things. Srx's of course have this problem as well, but not so often. I have my oil pump turned up, Srx rear cooler installed, and I run Srx heads with safe jetting and so far so good.
