I unhooked the speedo cable from my 99 vmax 500 and I took the cover off of the drive shaft end, on the chasis behind the secondary. there was some grease in the cover(cap) and I cleaned it out. should I put fresh grease in there ? there is no grease nipple on there. how did the grease get there ? what grease? snowmobile or wheel bearing ?
There should be a grease fitting underneath where the cable screws in. And yes there should be grease in there.
snowdad4
no nipples on those unless its been added. hand pack with low temp lithium grease.
