Frantz600st
I just got a 600 vmax st. Have to rebuild the engine and fix the cylinders and head. Going to do wiseco and it has a rage cage on it already I'm wanting to adds more stuff to it for power before I rebuild it what could I do? Also, what could I do to raise the rear end 2-3 inches for a better stance for hills and jumping?
roudyroy1
port job, cold air intake, shaved heads, clutching goes a long way, pipes. it depends on how much you want to spend and how good of a mechanic you are. the more mods you do the less tolerance your engine has to non ideal running conditions, i.e extreme cold and bad fuel.
thefindian
Jumping! lmao you got the wrong chassis for that and the wiseco piston is not the way to go with that motor I just rebuilt a 95 600 for a friend and it was $800 for parts I only did the mag side, the crank and a cylinder got a rebuild and the oem piston, rings, wrist pin, wrist pin bearing, crank seals and base gasket was $200, hardly worth putting that kind of money into that chassis in my opinion.
Frantz600st
I'm redoing the entire rear suspension and the entire tunnel on it. The whole top end is being done why is a wiseco top end not worth it? I will be putting around 1200 into it so it'll last along way
staggs65
lots of opinions on wiseco's. Personally I have no beefs with them. You just have to be sure to let the sled fully warm up with them every time you ride, no shortcuts there.
Frantz600st
I don't mind warmiing it up first I run wiseco in my bike and I don't have trouble. I heard the stock pistons for this sled have problems with the rings spinning and going through them. Also my clutch side piston melted the entire top onto the head and its stock
Frantz600st
I would like to do drop brackets on my sled probably. Would the regular vmax work on my long track? If not ill make custom ones
thefindian
I was told by a couple different guys that the 600 motor was hard on pistons and oem was the only way to go.
quickest and cheapest is to build your own drops. you will need some 1/4" plate aluminum, 3/16" will work also. 5" x 9" if you want to retain the stock holes, 3 1/2"- 4" is a better look in my opinion, shaped correctly and skipping the stock holes and making your own. button head allens with wizlock nuts along with loctite are my fasteners of choice.
never had any unusual piston issues on my 94-96 vmaxes and always used oem for replacements. 97's had the piston/ring issue. put many miles on those old girls. only a few lean burns, self inflicted. to my knowledge they are still alive to this day. harder on clutches.
pipes, if you can find them, wake those sleds up. a timing bump along with high quality fuel is a cheap mod.
dont lift the rear too much as it upsets the handling of the non adjustable front end, unless you relocate the skid.
Vmax540
staggs65 said:lots of opinions on wiseco's. Personally I have no beefs with them. You just have to be sure to let the sled fully warm up with them every time you ride, no shortcuts there.
X2 !
If you don't want to go the twin pipes route, you could find a GYT single pipe for these sleds. There were quite a few sold over the counter, and they alse came stock on the 1996 600's. Another popular mod back then was a thinner head gasket (watch your fuel octane), and the 96's may have come with this as well, but don't quote me on that, it's been over a decade and a half on my memory...
Frantz600st
i have twin pipes on it now, the clutches were replaced by the previous owner. they must have been going out it had around 2700 miles he had put polaris clutches on it from a 99'. stock pistons are 100 dollars cheaper but i like wiseco everyone i know uses them usually. also i want to add around 2.5 to 3 inches on the back because it doesn't look half bad with the long track. i can go and cut out drop brackets on the cnc cutting machine in september when everything else is done. it sat for a long time broke down and half torn apart. should i throw in a new oil pump and fuel pump kit just to be safe or just clean them?
Frantz600st
what should i do to clean the bottom end without tearing the engine completely down?
thefindian
Tear it down and inspect every bearing with that kind of money on the line its not worth it.
Frantz600st
i was just looking at parts and the oil pump is 208$ how can i test mine to make sure its working?
Frantz600st
What shock should I do I think I'm gonna replace mine and do some bearings
Frantz600st
i have an exhaust brand question anybody know the brand "pt racing" i have twin pipes and thats the brand of them are they any good?
