tnc110 said:
The best penetrating oil is a 50/50 mixture of acetone and ATF...I read a test somewhere and it puts all the "over the counter" mixtures to shame. If you tip the sled up so that gravity pulls the mixture down through the threads it will help. soak it a couple times a day, then lay the heat to it.
Machinist's Workshop magazine. The magazine reports they tested penetrates for break out torque on rusted nuts.
They arranged a subjective test of all the popular penetrates with the control being the torque required to remove the nut from a
"scientifically rusted" environment.
*Penetrating oils ........... Average torque load to loosen*
No Oil used ................... 516 pounds
WD-40 ..................... ... 238 pounds
PB Blaster .................... 214 pounds
Liquid Wrench ...............127 pounds
Kano Kroil .................... 106 pounds
ATF*-Acetone mix............53 pounds
The ATF-Acetone mix is a "home brew" mix of 50 - 50 automatic transmission fluid and acetone.
Note this "home brew" released bolts better than any commercial product in this one particular test.
Our local machinist group mixed up a batch and we all now use it with equally good results.
Note also that "Liquid Wrench" is almost as good as "Kroil"
for about 20% of the price.
Steve from Godwin-Singer says that ATF-Acetone mix is best, but you can also use ATF and lacquer thinner in a 50-50 mix.
*ATF=Automatic Transmission Fluid
http://www.vintagevmax.com/vvforum3/viewtopic.php?f=2&t=2350&p=8717&hilit=acetone#p8717
