Corey9965
Will paint hold on my bellypan plastics or should I just buy some 98 plastics. I was thinking about priming and using bedliner paint. Will it crack and flake? Has anyone ever tried this?
shaggyzr2
Paint will hold but it takes alot of prep work and u need to use good quality paint that is used for painting plastic on vehicles. In the long run it would probably be easier and cheaper to just find a good used set of pans.
I have had good success painting the bellypans on my SXR.I wanted to hide the black exhaust stains on the belly pan.I cleaned her up good and used Krylon Paint for plastics,no priming at all.Really held up well and is still after like 5 years.
Paint
My buddy painted his seat with paint for vinyl . Nothing flexes more than a seat and it holds up well. So I would imagine you could use the same paint.
yep..todays paints are much superior then paint back 10 years ago.I painted old Yamaha skis on my SRX with Blue,will see how long it will go for..
Corey9965
Right on guys. All black SRX ia in the works. Hood is getting base clear by a local body shop for $100. The rest I can do myself. Thanks for the help.
