Hi all new here! Just picked up a 2002 sx600r what are the best mods to do to liven this sled up? I am going to do the can mod. Thinking about a little clutch tuning (minor) and extending it to a 136 with a cobra 1.352. What does everyone think? I bought the sled late last winter with 4800 miles on it for $800
99srxracer
Reeds cold air intak mod one layer base gasket gearing redheads are great motors
Do I need to go to an 8 tooth driver to put the cobra track in or can I just take out the tunnel and heat exchanger protectors? I am not goin to stud it. The 8 tooth drivers would be like lowering my gears wouldn't it?
99srxracer
That im not sure of but im sure u need to get rid of protectors
Thanks 99srxracer I'm hoping someone on here has done it! Will the can mod make a noticable difference in power or is it more in sound?
super1c
Super Moderator
Check out the tech section if you havent already. Many good cheap, if not free mods to help these engines out. With the protectors out you should be able to fit that cobra under there no problem with nine tooth drivers.
http://www.totallyamaha.com/snowmobiles/aaTECH/TechIndex/sledTechIndex.html
Thanks super1c! I like the fast responses on here! I don't know if it is just me been checking the tech sections haven't found much on lug height fitment for the sxr.
Jamie the 9ths work up to 1.5 in but do need take out the tunnel protectors. I told ya id help i set it up.
I have a 136 ready to bolt in and ride if you are interested.
http://www.totallyamaha.net/forums/showthread.php?t=92126
I could have it to you in less than a week.
Thanks Joe! not sure when I'll have the money to do it yet but I will get ahold of you when I do!
Thanks JD but I like the tracks usa kit they quoted me $530 for the whole kit with the cobra track.
Wont cost alot just some time and beers may need a different set of clutch weights il put up a post later of bluemonsters sxr 600 he was tuning
What do you think about gearing Joe? Will I be alright stock with a 136 under it?
Should be ok its 20/39 stock could put a 19 on top reed spacers and notched stop with a 2 layer head gasket should be a screamer with a good clutch set-up. Witch u dont have now.
Clutching with stock weights 8dg
http://www.totallyamaha.net/forums/showthread.php?t=75891&highlight=sxr+600+clutching
With stock weight from MM 8cr
http://www.totallyamaha.net/forums/showthread.php?t=89421&highlight=8cr
clutching
