does this look right???
tnc110
VIP Lifetime Member
NC
Just installed a m10 in the 600srx. flipped the front shock brackets. Might be hard to tell in the pic, but it looks like all the weight is on the front of the skid. The rear wheels are not touching at all. Is this normal? What else can I do? Jack the preload on the front shocks?
Man hard to say. The the srx sits pretty low in the front and the m-10 really brings up the rear. My best guess is you need to long travel that front end to match the big jump up of the m-10. Viper front end would be your best bet. You only gained about a inch from the bracket flip and raised the rear a whole lot.
when you sit on the sled,that track should touch on the rear..should be fine,but like super stated..probably get the front end raised more to match.
