dugedug
 - Apr 6, 2004
Have a 136" track and although its cool that the front end lifts up when I open her up unless i'm slowing down I have little steering. Under part throttle what do I need to setup to keep the skis on the ground so I can corner? Also, is there a way to lift the back end up more either to give more movement or just for looks because it appears to sit lower than most i've seen? thnx. doug
6'4", 190lbs.
			6'4", 190lbs.
