SWEDE
My sled is an '01 that I bought used from a local dealer.Supposed to be bone stock.How much oil should it use?I am using about 1 quart for every 100 miles that seems like alot to me.What do ya think,some guy recently told me that jetting down the carbs from stock along with verifying the correct oil pump setting could lessen the oil usage considerably.Its odd though in the fact that it does'nt smoke excessively or foul plugs.I have'nt taken gas mileage,but it seems ok.I guess I'm looking for some opinions on this,am I all wet on this or is that excessive oil usage?Also where should the belt ride in the secondary clutch,mine is about even with the top of sheaves now.Its slightly doggy on the bottom end now.Could my deflection be off?Thanks in advance for any help you all could give me.
