DoktorC
I'm working on an et250 that I got for my son and of course I don't have a manual..so...I need some help. It's a 79 and has the splined crank. I've got the movable sheave off and spring cup but the bearing and fixed sheave I don't know what to do with. The is very little space between the sheave and bearing for a puller and I don't want to damage anything.
True2blue
If I remember to check I have an old Yamaha service manual in my shop, I'll see what I can find out
DoktorC
True2blue said:If I remember to check I have an old Yamaha service manual in my shop, I'll see what I can find out
That would be great...I've dealt with what I thought was everything until I met this little ET lol. I'd like to change the crank seals before I start messing with the carb....
jamie
You need a bearing puller/separator to remove the bearing and you will notice 2-3 threaded holes on the fixed sheave so you can use a steering wheel puller to remove it if my memory serves me right.
DoktorC
Thanks for the advice...it was exactly like you said. once I pulled the bearing I found the treaded holes in the sheave for the puller...it popped right off. The crank seals weren't great and one of the crank bearings was noisy so I replaced everything and she's back together. I'm now cleaning and painting some of the shrouds and replacing all the mismatched hardware with factory stuff....ive got lots laying around...including the obsolete crank bearing lol.
DoktorC
That's awesome! There's nothing more fun than doing a job you enjoy for someone who you know is gonna love it!! Put up some more pics of the beast when its complete!
