Pioneer primary springs??
FJViper
Seacoast NH
Has anyone had any experience with Pioneer's Blue or yellow primary springs? If so, was it good or bad?
:letitsnow
Yeah, I read the engagement was higher. How much is too high? depends on the individual i guess. What was yours at Mopar? Also the spring rate is higher so faster upshift? Looking for whatever I can squeeze out of my Viper with the 53/43 w/ 4.5's in tip. Was going to go with Clickers this year but opted for a new Hacksaw track instead.
Thanks for the info.
well i guess maybe depend how u adjust your primary weight ..over 4500 5000 the clutch always overheat went u go slow or on a road crossing road and so on ..maybe if u put more weight in middle to give it more push it will maybe solved the problem ..
engagement will be different from weight to weight and how u will set up them ...
Engagement will depend on roller size, spring, mass of weights, engagement flat, is there an engagement notch, is the weight tucked, etc. I dont recall what the engagement was. It was a few yrs back that I messed with the pioneer blue spring in my viper but I thought engagement with my primary setup at that time being like 4500.
I agree the blue spring was around 4500rpm. Great spring. Yamaha makes a spring very similar in specs with a lower engagement if need be.
