vipersrxhouse
Ok hers the skinny
Have a few srx's and a few vipers
Looking for the ultimate combo between the two
I have a triple piped Hauck bult 700 in a long track sled and love it.
Just acquired a viper that has a set of Hauck pipes clutched and venom heads v force reads ect... I also have a SRX with a 780 big bore kit long track viper 136 skid and viper long travel suspension in the front. I like the looks of the viper over the SRX . Thinking of the SRX big bore engine with the venom heads and water rail in the long track suspension sled. But what to do fore exhaust? Thoughts suggestions ? Thanks
staggs65
If you're going to run the srx engine then you should be able to get the SRX pipes to work fairly easily. Srx pipes have been used on Viper engines and the biggest problem is building the manifold to go from the Viper cyl to the SRX pipe so you should have the hardest part licked. The other part is you need to use the srx cdi with a resistor in place of the coolant temp sensor to fool the sled into thinking all is hunky-dory. You also need to cut the Viper belly pan for pipe clearance.
Oh yeah, and the venom head domes will need to be recut for the 780
vipersrxhouse
thanks for the info
i know it wont be a drop in but should be well worth the effort in the long run
any one else have any input ?
staggs layed it out pretty complete, nothing left to add.
