roudyroy1
Can some one post a picture of what reed spacers are supposed to look like? I am trying to fabricate my own and don't know if I have them just right.
they look just like the reed block gasket does only thicker.
roudyroy1
I find The plans in the tech section aren't very clear for the center cut our pieace. Could I just trace one of the gaskets?
ya, use the gasket as the template.
roudyroy1
thats what i just did, i decided since the gasket is commming off anyways might as well do it now and use it as a template. btw are these gaskets reusable? if so are is there any preparation to re use it?
you can reuse the metal ones with the black coating. if the coating is not too spiffy, i just dust them with copperkote gasket spray lightly.
but with spacers youll need 1 extra set of gaskets.
engine>gasket>spacer>gasket>reedblock>carb flange
roudyroy1
Alright, thank you.
