bought a used track. The outside picks are worn quite a bit...below the lugs. Should I remove them or leave them. Wondering if un occupied holes is a bad idea?
Im currently running a track that was once studded without any issue. Just remove the studs and burn the ends of the threads with a torch so they don't fray inside the track and you should be fine.
