just,got the call back.
Ok, well to have the valve reanodized like original is gonna be $35 each. The anodizing would have to be done BEFORE the end is repaired as you cant put steel into the anodizing tank. I have to submit batchs of 12 or more parts.
So going to the post before, I am going to buy used valves both viper and srx and have a set of 12 of each done first, then repair the ends on them to have as the exchange program, its the only way to do this as the turn around time is 7-10 days from the plater. I can hold to my 1 week turn around on my end by doing a exchange program. If you send me a valve thats damaged on the face,rippled,gouged from piston hitting the edge or something other then the end being pulled thru its gonna not be a flat out exchange for a good valve repaired.
if there is minor rippling(common) on the tops or bottom that will just be plated over as it really doesnt effect the valves operation.
so as of today, if you want the valves repaired I am ready to do so.
If you want them recoated, I can NOT do this till I have my exchange program up and going which will be a little bit of time to collect/buy 12 viper valves, and 12 srx valves to have ready to exchange out.
I am aware a new valve is $105 new, so if you had the coating done and the end repaired youd still be saving basicly $30 each plus the valve will outlast a new std one by 10 times as the end will never pull out again. set of 3 youd save $90 over buying new yamaha ones.
NOTE: Once a valve has been repaired on the end, it can NOT be recoated/anodized again.
