Alaskanparret
Well after cleaning the sled all up this year and dealing with my throttle cable being messed up from the connections not going together. I finally thought I had it running all good to go.
Apparently not. Now I get the TPS error code. 2 long flashes followed by 1 quick flash.
Went online to get a new TPS and it just says,"part obsolete" so now what?!? I'll throw a few more hundred dollars at this things before I reach my limit.
So do I take it to the dealer and have them work it out or what?
is it plugged in on both ends, at the sensor and over at the wire harness by recoil?
Alaskanparret
well i finally got around to checking it tonight and sure enough i had forgetten to plug that connection back in. fixed the flashing light issue!
thanks for the reply! one less thing I have to stress about. you guys are pretty smart here
