roudyroy1
so i got my sled going(finally) when i was running it i noticed it was a little bit smokier than normal, after shutting it of i looked at the throttle block to find the oil cable with a loop in it, so i pulled the carbs and uncovered the pump and this is what i found. [video]http://s1281.photobucket.com/user/roudyroy1/media/VID-20131114-00023_zpse436ce98.mp4.html[/video]
video is freezing, but if i flip the oil pump arm fast, it does not hang up, but if i hold it open for a little then let it down it hangs up as seen in the video. the reason it was smoking like i said was because the pump arm did not retract all the way. i did pull the spring off and it seems to be coming from in the pump
any ideas whats causing this?!?!!?! what do i do now?
