saskviper65
Bought a new 9254C track, 1.75 x 141" 3" pitch for the 2000 MM. Was planning to use 3" 7T Wahl bros drivers, about the same dia as the stock ones. Here's the problem the track is designed for the arctic cat diamond drive drivers, so the outer drive lugs are smaller and are doubled up so they hit the drivers.(cat only uses these for a guide). So either I cut off every second lug or modify the drivers to clear.(probably going to modify the drivers) Anyone have any ideas?? Or does someone make a cross over driver?
