fresh out of storage exhaust joint leak..
Guess even a 60w light bulb might be enough..my problem is it's 250 mi. to my cabin and I'll probably need to use the sleds at least by 12 hrs. after arrival...need a quick dry solution or cross the fingers..if it fails only out penneys and could redo on the way out...sounds like a plan if the leak off the manifold joint don't kill me riding.
From Permatex
Recommended for manifolds..
DIRECTIONS: 1. For best results, clean and dry all surfaces with a residue-free solvent, such as Permatex® Brake & Parts Cleaner. 2. Cut nozzle to desired bead size – gaskets are best formed using a 1/16? to 1/4? bead. 3. Apply a continuous and even bead of silicone to one surface, surrounding all bolt holes. Remove excess with knife at once. Assemble parts immediately. Do not squeeze out silicone by overtightening bolts. Re-torque will not be necessary. 4. Silicone dries in 1 hour, and fully cures in 24 hours, at 70?F (21?C) - 50% relative humidity. Allow more time in cold weather. 5. Replace cap after use. Clean hands with dry cloth or Permatex® Fast Orange® Hand Cleaner. Clean tools with non-flammable cleaning fluid. NOTE: Not recommended for use on head gaskets or parts in contact with gasoline
oh yeah a 60w will work!at my cottage up north in the fall times i put a 100w light bulb in the pump house encase is drops below 0. believe me they put out a fair amount of heat, its saved me more than once! the leak really wont hurt anything, i just sealed it up because i was sick of black oil an crap sitting in my belly pan from itdripping from the pipe on cold starts.
