SRX98Bradley
What front suspension is better for a SRX, ohlin's or viper stock shocks?
Devilin AblueDress!
Viper shock on a SRX requires an adapter, Betheviper used to make and sell them but I don't know if he still does. Pretty sure general consensus will be no comparison....Ohlins are better hands down. SRX or SX versions should bolt right in. I think Amatosrx had some for sale.
Sold all set no more left.
SRX98Bradley
I have ohlin's already, was just curious on the stock viper shocks, thank u for your input guys
If I'm reading right, it's kind of an apples to oranges comparision. Viper's are a long travel and stock SRX are short travel. The Ohlin is a much better shock then the KYB but if you're looking for big bump performance the SRX Ohlin is limited in it's travel.
99srxracer
If you use an extra set of the round bushing that ur shock bolt goes thru you offset the top of shock over on the mount grind the bushing w/ a bench grinder down a little and your good to go. Cheap and easy done it to many yams w/ no problems
