Replace proaction for the SC4
alsim1
Montreal
Quelqu'un at-il eu de bons résultats avec cette installation sur la vipère? J'ai la possibilité d'acheter SC4 mais je ne sais pas où je vais placer et percer les trous pour l'installer. Est-il compliqué à faire?
If it's not the best way to go, maybe just remove the transfer rods and replace by the transfer staps ?
Alsim
Sorry Guys
Did anybody had good result with this install on the viper ? I have opportunity to buy SC4 but I don't know where I will place and drill the holes to install it. Is it complicated to do?
Alsim
Maybe going with the transfer straps (50 bucks) ? I want more transfer for my viper. The other option for me is the SC4 if it simple To install
Alain
I installed a SC10-3 in my Viper, It was a great upgrade. Plus waay cheaper to re-bushing than the Pro-action. I followed the install thread from an SRX I believe. I had to use CB drop brackets to get ski pressure.
I also had a few pictures of the install in a build thread I started last year.
Wow ! J hubbs very Nice .
Where did you get the rear mounting plate ? Could you pm me if you have all the mesurements to install it .
Distance between the center of drive spocket To the first hole
Distance between the top of the tunel To the first hole
Distance between the first hole To the second rear hole .
Distance between the tunel To the second hole
I Will very happy if I have this info !
I Will install sc 4 probably the sc 3 have the similar mesurements
Alsim
