Been there done that had to clean carbs more then once to make run right at starting of the season. As far as clutch is had OE a y-g-y 40 123 I changed it to a y-s-y 35 118 If i remember correctly
mile9c1
Make sure you clean those little screens in the carbs, above the inlet valves. I'd for sure replace all 3 spark plug caps... lots of people have reported that new plug caps made a world of difference.
roudyroy1
alright, and you said flipping the choke fixes the bog? its definitely lean, how do the plugs look? re clean them carbs, make sure when you spray carb clean through the piolt jet you see it come out the little hole inside the carb throat. and blow every thing out real good with compressed air. some times it takes 2 or 3 carb cleans to get every thing out if its really gumed up
