need some help
did some more testing agents my 2000 sxr with the old ignition system. that sled was only putting out around 9 volts, but 10 amps! and the grips get smoking hot. the 2001 puts out 12 volts but only 3 amps, should i look for a broken wire? also does anyones highbeam/ low beam switch plug get hot under the handle bar pad???? mine warms up alot!
