Thanks in advance.
Sled is a 98 XTC Deluxe 700, I had a clutching set up put in by FIX power sports, more than 4000 miles ago. Runs Ok but not as crisp on back shifts and accel (* rpms are not changed for engage or shift point). I dont want to change set ups but what do I need to replace besides the belt? ?
-primary spring suspect yes
-rollers Y/?
-weights or should/can you get bushings only?
-other bushings or parts.
I am trying to decide if I do this myself and learn or just fork out the cash and wish I knew more? Thanks for you Rec's
I will be out of town later today, so check back on return
YAMADOO
-rollers Y/?
YAMADOO
