hereismylife
Reading the post on oil cable adjustment.
http://www.totallyamaha.net/forums/...p-question-SRX&p=570227&viewfull=1#post570227
post #3
What does the 1 inch mean? I only measured to make so it was only 20-22 mm
post #3
Devilin AblueDress!
"I think the adjustment is supposed to be 20-22mm at 1"
Can you share the thread where this came from? I suspect the " that you are assuming translates as inch, which I am assuming is the other end of a quote, due to the other " on the left side of the I that starts the statement. I assume the 1 is reference to the location of adjuster. With thread we can look of rest of contex and verify
staggs65
yeah, never heard the @ 1 inch thing.
hereismylife
I am looking for the thread now....
hereismylife
updated link in first post here
Also here
post #3
Also here
post #3
Devilin AblueDress!
I think the adjustment is supposed to be 20-22mm at 1" you are 25.4mm which is leaner then the stock setting COPY AND PASTED. First link works but your second doesn't.
Refer to post #1 where original posted stated he set to 1". His reference of 1 inch was at one inch =25.4mm.....
hereismylife
ok. got it. thanks
Link fixed
