Yamaha_Chuck
Well I finally got my sled running fairly well, it was an issue with the power valves that is now resolved. However I still have a few issues. The first issue is the cold start which I have read a lot on about here, but mine is getting plenty of fuel in the cylinders as it is soaking the plugs and you can smell the gas.....only way to get going is to add fuel down the cylinders.
The other issue is an idle issue which might be related to the starting issue, not sure. After it warms up it idles at a steady RPM but make a strange backfire, almost like a poof sound, not a bang.
And lastly, from a dead stop, when I punch it, it will almost die out. Other than these problems it works A1 out on the trail and pulls strong. Any advice would be great. Could it be the fuel screws not set right?
