how many chisel are the best for the srx 700 for 660 ice
		staggs65
I ran a mix of 120 ice picks and 48 chisels on my Viper last year and it didn't spin at all. probably could have gotten away with less picks
			soo I guess 100 chisel and 44 trail stud should work fine ???
		staggs65
I would think so
			I got 144 trail stud right now and it doesn't hook at all ....not fun on ice like at all
		staggs65
yeah trail studs don't cut it on ice for 660 racing. I actually started out with just the 120 picks and threw in the 48 chisels as the track deteriorated. The picks work great when the starting area is still fresh but the chisels work better when it's tore up. I'll probably be running just chisels if I ever get the SRX out this year.
			jabber800
What track and how much penetration?
			its a 1 inch that have  been shaved to 7/8 ..what kind of gear does srx like on ice for 660..i wanna make sureit hook to have fun with buddies..it got more than 1/4 inch if I remember
		staggs65
1 inch track is going to make a difference. I run a camoplast 9811R it's only a 1/2 inch track
			im sure it  will make a difference ...will  see how it goes ill put 144 in the middle 1.075 chisel and see if its hook
			im not sure if  I can run longer chisel and be safe
			21/39
			21/39
this will change my clutching ...... I will need to add more weight right ?
I got 22/39 not sure if I can still find any 21 gear non hyvo
			13 wide or 15 wide??
ya a lil bit, i would run it first then adjust, let her get up to 8600-8700rpm
eewww, you can save some rotating weight by going to 13 wide.......
you can still get them new in 15w at wahl bros, like $36 for one
i know about the weight its only because i already have the 2 chain 68 and 70 from a long time ago and gears ...its not big race its just friend race ...i need to wake that srx since they all have newer sled
last question i try both ramp but not really on ice ...8bu-10 or 89a-10  should i run ....i think the 89a10  pull more from low to mid but i  try them more for top end ..did really like the 8bu-10 ...no heel clicker in my box lolll
