sledneck1986
Hi everybody, I bought a SRX700 last winter and I falled in love with that sled. I had no major problems and I was planning on changing pistons before they blow. But I was lacking time this summer and didn't work on it, just started it two times in the summer.
So snow came early here this year and I started the sled. It was not running as strong as last year so I cleaned the carbs which helped a lot. But I was still feeling a flat spot near idle/low rpms. It was stretching the arms at wot, as always.
But the other day the engine blew, I heard a noise from the engine and it started backfiring. Back home I checked compression and from the clutch 130-130-0. I'll post pics, but on the exhaust side of the piston there is a hole on the side and the top of the piston is really damaged. Seems like it was running lean and it overheated a lot. I'm now in the process of rebuilding the engine and I found this forum where I think some people will be able to answer some questions I have.
When disassembling I recleaned the carbs, and the pilot jet from the carb of the faulty cylinder was clogged again...so heres the 1st question; Is a clogged pilot jet enough to blow an engine?
Also i found that on the faulty cylinder the power valve seemed to be stuck open and dry, the two others were moving freely and oily. 2nd question ; is the stuck open powervalve the cause or the result of the blown engine?? I mean, assuming it was probably stuck open before the piston break, can this be the cause of the blown engine? Or maybe this cylinder came so hot that the valve has jammed open...
I hope you can read me, English is my second language, anyway the pics are gonna talk by themselves!!
