Bravo Carb Question
RocketManRod
Thunder Bay On
Having problems getting bravo to run on open throttle.
I have two of these units. Removed the carb and cleaned, remove main and pilot jets, cleaned real good. as i was blowing air through the carb when i blew through the pilot jet orfice i feal air comming out the top of the carb?? So i went to look at the other bravo i have in the garage and on that carb there is some type of plug on the carb. Now i think i have found the problem i am trying hoe to figure out hoe to fix?? can i totally plug this or can i just cover the top with something??
Thanks ROD
