1hillbilly1
Hi all new to the Yamaha world. Just purchased a custom build sx viper sno x sled. It had a hauck 900 in it that blew the center rod through the case. Then the guy I bought it from put in a stock 700 and center rod bearing went so he pulled the crank and send it to northern up in thief river and they put all new bearings in it and sent it back to him. He then reassembled everything and it ran great for about 300 miles and a noise started coming from engine. So he parked it and I bought it from him I pulled the clutch hoping it was just clutch noise and it wasn't so I decided I would drive it home and pull it apart and see what I could find. Well I made it about two blocks from my house and boom center rod through the case. Is this a common problem with these engines? I wanna rebuild it, but don't want this to happen again. The sled does have a full slp triple pipe system. Also if anyone is looking for a hauk stroker crank with the two good rods, the cylinders, powervalves, and the head I'd be willing to do some swapping for the parts I need to get this thing up and going again. Any help would be greatly appreciated.
