s10mike
does anyone know what could have wrecked the bearings in my chain tensioner? i took the chaincase cover off, took out the gears and chain/tensioner and cleaned it all good. put it back together, filled the case with trans. fluid. i put about 200 miles on it after that. i took it back apart to take out my skid for shock rebuilding and the chain tensioner bearing is gone. enough that it chowed up my gears a little. did i put it together wrong? has this ever happened to anyone else? i want to make sure it doesnt happen again. thanks
just mileage, I have replaced them before in sleds. Not super common but more then 5 or 6 in the last 5-8yrs, so its somewhat normal.
just put a new one in it and youll be good to go for a long time.
s10mike
thanks mr.viper. you are very helpful. i apprecieate it.
should add also, when you put the new bearing in the roller, put some good wheel bearing grease on it, and then add the 2 end seals.
s10mike
i bought a whole new tensioner, it was cheaper than a new bearing. from an o4 viper with 3000 miles. thats what he told me anyway.
ya i think the whole thing,roller,bearing,2 seals is like $40-45 from yamaha.
when you get your new one, just take off the clip, pull the pin and remove roller, pop out 1 of the seals carefully and grease the bearing, reinstall and they last thousands upon thousands of miles.
Backwoods M Max
I'm doing the same thing myself. There are no seals. Bearing goes in the roller with a washer on each side. Tech manual says to change the pin with the bearing since it is the inner race.
