deekersrx700
When I bought the sled last spring the speedo wasn't working. So I found the speedo gear box stripped so I replaced it and the little shaft thingy. Go for a ride and it works great for 10 mins then no speedo again and the odometer is way off scale. So I decide to try a new cable. Same thing?? Well it must be the speedo itself as it is the only freakin thing left. I found a brand new dash cluster on ebay with 0 miles so I pick it up. Install it this morning and go for a rip and gues what same freakin thing!!! I take the cable off the speedo and fire the sled up on the stand and the cable is spinning with the throttle. So I take everything apart again and make sure everything is ok and it appears to be. So I put it all back together and fire the sled up on the stand and the speedo works ok again. I'm guessing it will do the same thing it has the first three times and quit working after about 10 minutes. Has anyone else had weird issues like this??
