yamatyb9
Find your TPS on your carbs follow the wire back their should be a two connectors disconnect and reconnect the wires together that lead into the harness and not the one on the carbs. This bypasses the TPS system so now you can determine if this is your problem or not . When it is active it will not let the machine rev past about 3000 so the primary can not engage. Just had to replace my ol lady's on her rx1 sounds very similar to what happened to hers.
