Skeeter1982
Hey guys. Just wondering if anyone knows for sure if I can add reverse to my 97 mm that has a ekholm tunnel with the drip and roll. The chain case has not been lengthened at all. Both jack shaft and drive shaft are inside the tunnel. Thx
if the chaincase has not been cut and welded,sure........ it will bolt right on.
Backwoods M Max
The location of the shift lever will not come out in the factory spot. If the chain case has been dropped that much the lever will come out through the right cowl panel.
Skeeter1982
Ok thanks guys
